Bedlam
Nov 27, 2018Moderator
kayco53 wrote:Sliding-into-home wrote:
Thanks for all that awesome feedback, especially on the tires. I had ko2's on my tundra for all seasons and then Nokian studs. No comparison.
I've heard mixed things about air bags though. Seems some love them, others regret. I'm going to start with the stable loads and then add a big wig if I feel like I need help with sway. At least that's the plan for now, but I'm nothing if not suggestible.
Check for clearance on the Stableloads that go between the leaf springs. Took mine off as there was no clearance for tire chains. If you get airbags make sure they are independent of each other truck is stiffer that way (less sway).
Mount the lower StableLoads inboard on the springs if they don't clear your chains.
