smooth1
Nov 28, 2018Explorer
Congratulations. Mountain camping at the ski slopes is great & a truck camper is a great way to go. (2) large batteries at a minimum & carry a generator. If you are going up for just Saturday night are you sure you can get a spot. RV lots at the slopes fill up fast in the PNW.
A note about the fiberglass campers and winter camping is the top needs to be cleaned of new snow over an inch or so before you head home. If not the snow will slide off the top of the camper roof and land on the windshield when you apply the brakes. This could be dangerous if it is too much snow for your wipers to handle.
Non clam shell/fiberglass designed campers have a raised seam on the front of the roof where the nose cap and roof join & the rubber roofs have better friction than fiberglass, so this does not happen on those campers.
Climb up and down the ladder for practice with a broom and when it is wet, & make sure your boots have good traction on the fiberglass as it gets slick.
