Sliding-into-ho's avatar
Nov 18, 2018
Arctic Fox 990 on SRW in the Snow?
Hi All,
New member here, excited to be joining your ranks. Less exciting is the prospect of wrecking my new truck and TC.
I have the truck (2017 F-350, CC, SRW, 6.7l, FX4), but not the TC. Reason being the safety factor.
I understand that AF990's weight is roughly 4k lbs. I'll never be carrying more than 1 day of water or LPG. Also opting not to get AC, Fox landing, solar, or any side awnings. I don't need any of the above, and all would save some weight (although I've heard carrying a bit more water can improve handling).
I'll do whatever I need to do on the truck (independent air bags at minimum). I plan on running Nokian LT2 studs (e-rated, and roughly 3600lb per tire). I don't care if they're destined to last only 15k miles, as I feel there's no safer way to transport my family in winter conditions.
Speaking of that, this camper will be used 99% of the time to overnight up on the mountain (5400ft climb from my house). I will have to make the drive every weekend, all winter, regardless of conditions (the first 2/3rds is essentially never snowy, and the last 3rd is highly variable (Mt. Hood, OR).
All of the above brings me to my hang-up. I know I could put everything together in such a way that I stay under my 11,500 GVWR, but given the weight of the TC, it wouldn't be by much. I wonder if I'm going to regret not leaving myself more overhead in terms of payload.
Ultimately, I know I can always slow down enough to make the trip safely, but I don't want to be "that guy" on the road who is holding everyone else up in single Lane sections.
As there will frequently be 2 adults and an almost-teenage man child camping, and since one of those adults is my wife, my impression from reading these forums is that a slide is almost a necessity. Would you agree?
If so, I could also consider a Lance 995 to save several hundred lbs (just felt like the AF had the edge in build quality, and with all the extra weight, it better!). I think I could even save a few lbs in a Host (but not a few dollars).
If not, that would bring Northern Lite into the running, which seems to make a lot of sense as an exclusive winter camper where weight is also a factor (especially the sportsman).
I'm sure if you've made it this far, you get the idea. Thanks in advance for any wisdom you can offer. I look forward to being a part of this community.
  • “I'll never be carrying more than 1 day of water or LPG. Also opting not to get AC, Fox landing, solar, or any side awnings. I don't need any of the above,..”
    So when you find that great campsite with those trout in the stream, you can’t say more than one day... Sounds terrible to me. And no solar since a generator and gasoline weighs less than two 100 watt panels and one pound controller? I disagree. Gets mighty boring going to the same place 99% of the time. Build a cabin or plant a TT on site. Three adults (two and one mansize male teen) in a TC won’t be fun.
