jimh406
Jul 07, 2021Explorer III
Based on what I found online, your rear tires are way over capacity. They are only rated at 3000 lbs each. Your rear tires are probably overloaded by 1500 lbs. I agree that your air bag pressure is really high. Buy some extended bump stops and make sure the overloads are engaged.
But, the main issue is probably the tires.
