mkirsch
Jul 08, 2021Nomad II
If it didn't rock with the old tires and wheels, then the solution seems obvious to me. Put the old tires and wheels back on. If it stops rocking, then your new tires and/or wheels are the problem.
What wheels did you use? There are wheels designed to carry loads, then there are "bling" wheels meant to just look good.
Your tires are rated for 3748lbs each (load index 126). With a ~4K camper you're already at 7000lbs+ on the rear axle.
