Bedlam
Sep 29, 2015Moderator
The jack extension brackets do allow the camper to wobble a little more than without them. Blocking the TC underside or using WobbleStoppers from Torklift will reduce that movement. I have no worries about the brackets being of adequate strength to hold TC and occupants in regular off-truck use.
The DRW is not any wider than your TC sitting on the back. When driving unloaded you do need swing right turns slightly wider than a SRW, but nothing different than when you carry your TC. The biggest obstacle I have found with my DRW is overall length fitting into a spot rather than width. I went from a SRW extended cab short bed to a DRW crew cab with 9' deck and no longer fit in the 20' deep spots in my area.
