Reddog1
Oct 06, 2015Explorer II
I am impressed with what you have picked up. I think you will do well, with a minimum of surprises.
bobbolotune wrote:Side winds and semis will still push you around, but not as much. You may find that a sway bar will really help, and not all trucks have them from the factory. If you have to buy one, get the largest diameter bar you can.
... The talk about that with a dually the wind or a passing semi doesn't push you around. That is what pushes my decision to want a dually as the priority over parking and snow/ice.
bobbolotune wrote:I see deully snow plows and sand trucks, and I have ask why is that if the duelly is so bad in snow and ice. I do not recall ever getting an answer.
In more detail, specifically my original question was about using the truck without the camper for my daily drive including in the winter (with the camper off the truck, since I don't plan to winter camp). The response was that you are not going to rule the road with a dually, but especially with 4x4 you will get by.
bobbolotune wrote:I think that is an individual thing. A lot has to do with where you live. I have had my 1996 2WD truck for about 10 years. I have never needed 4x4. I recently purchased a 4x4 DRW, but that is not why I bought it, I really do not need either feature.
This surprises me in all the discussion I have read it never came up before that this is another reason to want a 4x4. Truck Camper Magazine did a reader survey about 4x4 where the majority opinion was yes for 4x4 being desirable (because there will someday be a time when you are very glad you have it). But I now realize that discussion was all about (summer) camping. Now this is another reason for 4x4 that it helps if you want to use the truck as a daily drive in the winter.
bobbolotune wrote:Must be doable, sure are lots of them on the road, including in snow removal equipment.
Multiple people said they have extensive experience with duallys on snow and it is workable. My conclusion is to not let concern about snow and ice talk me out of a dually.
bobbolotune wrote:My preference is to not use my TC when it is off the truck. When I store it at home, I sit it on sawhorses. I presently have a Stable Lift, and it is very stable without sawhorses. Before the lift, I had hydraulic jacks with the bracket extenders, even though my truck was SRW. The brackets did increase the wobble. However, it was only a serious issue loading or unloading in windy conditions.
As far as dually brackets, the short answer was don't worry it. You may get more wobble with dually brackets, but people do camp off the truck with dually brackets. Torklift Wobble Stops will help, or as one person said "old fashioned blocking".
bobbolotune wrote:I have owned several TCs since 1972. I have been camping longer than that. What I have seen in jack failure is the mounting screws pulling out of the wood. The mounting extensions are very stout, and I can't imagine them failing by themselves. Certainly possible. The jack mounts are shaped like a piece of angle iron, and depend on the shear to carry the load of the TC. I have never understood why a plate is not across the bottom, which allows the place/mounts to lift the TC. The bolts would then only hold the mount to the side of the TC, and have no shear. I have repaired many mounts using this method.
There were several stories intermixed in the responses about failed brackets and brackets separating (whether it is the bracket itself or the connection to the camper, for example 54suds "I have seen at least 4 campers who's swing out brackets bent to dangerous angles"). I would think the laws of physics say that the further the jack is from the camper the more stress there will be on brackets (same as the longer the tow extension the more tongue weight on the hitch).
bobbolotune wrote:I suggest the horse mat go at least 1-inch or more outside the TC floor. This provides support for the side framing of the TC. I have used the mats before, and think they are great.
It doesn't sound hard to take some extra care and jack the floor. I am thinking when I get the 3/4" horse mat for the truck bed mat that I will save some pieces to glue onto boards for the jacking. That cushion would be good to protect the underside of the camper and give some stress cushion.
bobbolotune wrote:It depends on the side rails of the truck and side wings of the TC. When I loaded my TC, the TC side wings and truck side rails only had 1-inch clearance. I put 4x4's under the TC. That allows me to use the area for storage. Newer TCs may provide more clearance.
Then the next question is where to store the jacks when the camper is loaded? Possibly the jacks and boards will fit into the truck bed between the wheel well and cab (I don't know if that is possible, maybe someone knows the answer to this).
bobbolotune wrote:I have never used the Wobble Stops, but I think you you have it figured out.They also reduce or eliminate movement in the TC when used off the truck.
So it seems floor jacks and Wobble Stops are two solutions to wobble, and both will reduce stress on the camper jack brackets. But I would think jacking will reduce more stress than Wobble Stops. It is carrying the Wobble Stops vs carrying the jacks. The Wobble Stops are probably easier to set up (and have the anti-theft feature), but if jacks have the added advantage of reducing more stress on the camper jack brackets that is a tradeoff.
bobbolotune wrote:Most of what has been discussed here depends on your camping style, camping preferences, and comfort level. Using your truck as a Daily driver will also influence your choices.
I have a lot of other learning curve here. I could defer the whole topic by at first just leaving the camper loaded on the truck. Get through the other learning curve topics in my early camping (remember that I have zero truck camping experience), then work on wobble, jacks and blocking later.
bobbolotune wrote:My TC is 11.5 feet. The only restrictions I have is towing a trailer. I do flat tow (no tongue weight) my Samurai (4x4), and have been known to load it down. If I were to tow a trailer or boat, I would probably have to add about $2000 in hitch related stuff.
For me, I am looking towards a lightweight non-slide long bed with minimal overhand camper on a dually. With that rig the camper will be about the same width as truck, and the rig will be only slightly longer with the camper on the truck.
bobbolotune wrote:Your thought on this subject is what I practice. It is so seldom I unload my TC when camping I don't remember when I have. I do typically tow my Samurai and use it for site seeing, especially if I am going to San Francisco. I see many people really spread out when they camp. I do not. I keep stuff pretty much in their storage place unless I am using it. Outside chairs is about the only thing I have out. There are exceptions.
I don't see what the advantage will be of unloading the camper. With the rig I am going towards parking won't be easier with the camper offloaded. I suppose less weight to carry for local drives, but the difference in gas cost couldn't be much for limited miles local driving. I suppose to avoid unhooking the electric and water to drive into town, and maybe having to level again when get back to the campground. But is that worth the trouble to unload the camper? This is an opinion I have heard before that this is an advantage of a non-slide lightweight camper (if you are willing to live in a smaller camper, which I am) that then you can leave it on the truck. Experience will tell. And this is a question. I am changing the subject asking for opinions about why people want to unload the camper.
