Bedlam
Oct 07, 2015Moderator
Sorry, I have four 4x8x12 blocks of wood. I use them to level the truck when the camper stays on, level the ground under the jacks when the camper comes off, and block the underside of the camper when it is lowered.
Typically I put two blocks on the front corners at 45 degrees while sitting the 12" end on the ground. 8" height is all I need to take a little weight off the front jacks and eliminate wobble on my Arctic Fox.
