truckcamperonmy's avatar
Mar 27, 2014
Are LED Marker Lights Better Than Incandescent Markers?
My 2011 Arctic Fox came with LED markers…I think that may have been the first year their exterior lights were standard LED? Anyway, I just recently had one of the front Amber LED markers fail and a lens cover came off one of the two side amber LED markers that is still working. I swapped lenses to protect the working LED and I'm waiting for two fully sealed LED markers from etrailer.com to arrive that another TC'er recommended here on the forum. Clicky
I also have two failing LED markers on the rear of the camper…one dimmer than the other, but on their last legs.
This made me think, maybe incandescent marker lights are better? When they burn out (in theory more often than LED) all you have to do is pop off the lens and slam another cheap little bulb in. Spare bulbs take almost no room compared to a full LED replacement marker and bulbs are more readily available and cheaper. I haven't replaced the LED yet, but I'll have to unscrew it, rewire it, and re-caulk it…what a pain!
Anyone out there switch their LED markers over to incandescent? Sounds crazy, right?!?! I'm all for conserving batteries by using LED for all interior and outside entryway/awning lights (I've switched all mine over to LED, but maybe old school is the way to go for markers that are only on when the truck is running?) LED tail/stop/turn lights are much more visible than bulb-style. Although, one of my Bargman LED tail/stop/turn lights died too and I had to replace that too. Not the cheapest lights either.
Although I already made the plunge and bought the amber marker LED lights, I haven't pulled the trigger on the red marker light replacements. What would you do…replace burned out markers with LED or incandescent?
  • In the OP's case, I would think that having removable lenses is a path to failure regardless of what the light source is. Buying a sealed light and applying some moe sealant at installaion would likely provide the longevity.
  • My trailer has the standard Bargman #59 clearance lights. I replaced the incandescent bulbs with their LED upgrade kit. It retains the same base and the sealed LED board/reflector/lens assembly just plugs in. No failures in 4 years. The nice thing about this is that the light base is intact and if you do need to change a light it just snaps in place.
    I do think they are brighter than the original incandescents.
  • I just replaced all of my marker lights on my 76 Amerigo TC last week. Wow... What a difference. They are sharp, bright and (hopefully) energy efficient.
  • I would never go back. The advantages of led are just to great.
  • RoyB's avatar
    RoyB
    Explorer II
    The reason for the most of us going to LED lights was to save trailer battery power when camping off the power grid.
    The MARKER lights are all powered by the truck start battery system so there is no real power saving for the camping part.
    The LED lights probably put off the best lights if you buy the right one. I notice almost all big truck lighting are LEDs now...
    Regulated type LEDs will emit RFI signals that may interfere with your home entertainment items... I know my Ham Radio picks up noise pretty good when I pull up behind a tractor trailer truck which I suspect is coming from their LED lights...
    The only way the LED lights start getting dim is burning out some of the individual LED strip lights inside. This is probably due to cheap LED lights are being used or not rated high enough for the varying DC voltages associated with the truck charging system. Regulated LED assemblies that operate from 7-20VDC would most likely solve that problem. High Vibrations should not be a problem with LED fixtures. Poor weather seal however is probably a big problem.
    Just some of my thoughts here
    Roy Ken
  • My AF 1140 came thru with regular incandescents. They were the typical cheap ones with the removable cover. One of the first things I did was replace all of them with sealed LEDs from www.ledtrailerlights.com. Two of the incandescents already had water inside the covers when I removed them, and the TC was about 2 months old. Once enough water builds up inside the light, guess where it goes? Did you ever see the big wire access hole that is behind each light on an AF? Sealed LEDS cant leak as long as you have them installed properly and caulked well. Im going on 4 years now with the same LEDs and never had one go out. I think a lot depends on the quality of the light.
  • Ivylog's avatar
    Ivylog
    Explorer III
    On a 2011 camper his LED longevity does not sound very good. Let's see... 10 incandescents at 1A each is going tax your charging system.:h Not sure LED equals more lumens.
    My marker lights are 10 years old and I have not replaced or cleaned any of them... guess I'm really lucky. Sounds like the biggest advantage of LED is if you forget to turn them off your battery will still start your truck in the morning.:S
    OP, is your wiring heavy enough to go back to incandescent although I doubt they changed it.
  • Well lets see :h...Incandascent lighting, Cheaper, Less space for spares, Easier to replace however Lower lumens prone to corrosion...
    LED lighting, A little pricey, depends on where you shop and manufacturer, Lower amperage draw,will not tax your charging system, Higher lumens, however requires more space for spares yet longevity is considerable however replacement is more intensive than incandescent.
    Also you have to consider the replacemnet bulbs that came onto the market and consider the reflective properties of each. The incandescent requires a specific type of reflector whereas the LED is a projection light which does not allow the full use of a reflector in an incandescent housing.
    In summary...Each type has its own advantages and disadvantages so the question comes down to which do you want.
    Good Luck
