JiminDenver
Sep 14, 2015Explorer II
We use three different LEDs. The first are small 9 emitter cobs down the center of the trailer that give a comfortable amount of light for sitting around. We have 48 emitter boards that were as bright or a bit brighter than the original 921 incandescent bulbs. They are too bright most of the time and we only use them in task areas like above the sink. Then there is the 120 emitter porch light. It throws light a good 30 strides away from the trailer.
So I guess it depends on what LED you are using to replace what incandescent.
