westend
Sep 15, 2015Explorer
Nothing worse than buying a dozen or more of a color temp and then find out it's NOT what you want/like.Exactly! I first read about sampling from Tenbear's posts about LED's. I believe he's right about that, as are you.
If my old peepers can be trusted, I've also seen a difference between alike panels but from different sellers. There should be no difference if all the LED's are the same size, type, and amount. Some that I have put out less lumens than others and the color is just a very small bit different. I experimented with my DIY fixtures (glass lense) and could just make out small differences.
