ktmrfs
Sep 15, 2015Explorer III
SoundGuy wrote:trail-explorer wrote:
The warm white LEDs I use are the same color temperature as incandescent lamps.
Doubtful. Incandescent bulbs typically run ~ 2600 degrees Kelvin, the warmest LED equivalents typically run ~ 3200 degrees Kelvin. If you have documentation that shows otherwise I'd be interested in seeing it. ;)
check out cree LED bulbs. the warm whites are 2700K.
