- Kayteg1Explorer IIWhen going camping, I am taking batteries from my sedans and boat.
No cost to me.
AGM batteries were design for upside down applications and are excelent for what they are design.
For camper use- it is just led-acid battery. - theoldwizard1Explorer IIDon't Waste Your Money On Batteries - The Shocking Truth I Discovered When Testing RV Batteries
This is a 36 minute video comparing various battery chemistries and manufacturers (sorry, no SiO2). My "executive summary" is LiFePO4 is the winner because of their life expectancy and depth of discharge (down to near 0% SOC).
Good old FLA 5V golf cart batteries performed well and were the lowest cost, but also a much shorter lifespan.
The interesting footnote was, AGM are really not worth the additional cost unless you are willing to pay the premium price for no liquid ! - bighatnohorseExplorer IIIt depends on what you mean by "worth it".
If you purchase lead acid batteries and take them back to the store where you bought them within the warranty time you may just find that they will give you new replacement batteries under warranty.
Costco did that for me and I understand that other stores do the same. - moonlitsoulsExplorerI just built a 280ah DIY Lithium phosphate battery for a total of $700 ,
1 x 100ah battle born goes for over $1000 so i got basically 3 of them for $700 fully built with the highest quality BMS , wires and lugs
Its fully programable and i can monitor/change settings using a bluetooth enabled app. If you're willing to take on that challenge you can save big. I am in the process now of sourcing another 280ah to double up on my bank giving me some serious boondocking capabilities with 560ah , upgrading the solar as well from 380 watts to almost 800w , should be fun - mbloofExplorerThe last time the #27 battery in my camper needed replacing, I went with a Battleborn. Here's my thinking:
- Lifetime cycles, while quality FLA's were rated at 300-900 lifetime charge/discharge cycles, the Battleborn was rated at +3000 cycles
- Capacity, the FLA's only have a usable %50, the Battleborn is nearly %100 usable capacity.
Charging - given the three possible charge sources, my solar controller had a LI setting compatible with the Battleborn, truck-2-camper charging was never really used (or upgraded to be useful) and the onboard Progressive Dynamics converter/charger was replaced with a LI compatible model (~$250).
To conclude, while the Battleborn cost ~2-3x what a quality FLA would cost, I believe it will last longer, have more capacity and be truly "maintenance free".
- Mark0. - spectaExplorer
jimh425 wrote:
Should be a fun thread.
:B - StirCrazyModerator
Avid Fox wrote:
I'm not sure I understand the charging setup.
My f350 has dual alternators that can deliver about 380 amps if needed. I already have giant charging cables back to the camper via a solenoid. Which work great BTW.
Do I need to limit the LI recharging to amp ratings and cable sizes, or just make sure the voltage is within range of 13.2 to 14.4? The Ford always delivers 14.4 to start, then backs off to 13.2 eventually when it senses they are fully charged. Will that work, or do I need something more fancy?
I would ut in a DC to DC charger. seeing you have dual altanators you can go with a larger one like a 60amp if your cables will handle it, but thats the best wy to charge the LFP batteries. you would also need to make sure your converter in your camper has a "lithium" setting if not just change it out for a charger section that does.
I dont know about down there but for the AH up here lithium is about the same cost as deicent high quality deep cycle batteries now (for the same usable capacity)
Steve - theoldwizard1Explorer IIThe big "win" on lithium batteries is that can be discarged down to near 0% SOC, repeatedly without damage. Lead acid should not be discharged below 50%, and for maximum life, not below 80%.
The second "win" is longevity. Any comparison between the two chemistries will take in to account that lithium batteries last 4 to 6 times (maybe more) longer.Avid Fox wrote:
Do I need to limit the LI recharging to amp ratings and cable sizes, ... or do I need something more fancy?
Some lithium batteries have built in charge controllers. Bare cells (which are much cheaper) do not. For optimal battery charging from your vehicle, even with lead acid batteries, you should use a DC-DC charger. - 14.4 volts is fine for charging. Best to limit charging to 50% to 30% of capacity on a regular basis. So a 200 Ah battery should be charged at 100 amps or less. Not going to hurt to put it in and see what happens a few times. And of course check with what is recommended by the manufacturer.
- Avid_FoxExplorerI'm not sure I understand the charging setup.
44,054 PostsLatest Activity: Dec 22, 2025
