stevemorris
Aug 04, 2019Explorer II
plumbing hookups including gas should be the same
but you will need a 12 v supply and a 120 volt supply to the heater. 12volt has to be on all the time, 12 volt controls the propane and controls the 120 with a relay. you will have to run 12 volt sized wires to the control panel(2 switches) which can be mounted anywhere. its either 3 or 4 wires from the heater to the control panel
http://diagramweb.net/img/atwood-g6a-8e-wiring-diagram-3.jpg
