enblethen
Dec 17, 2020Nomad
Locate the thermostat wires at the furnace. Should be two blue wires in furnace. connect them together. Furnace should come on, produce heat, separate the wires furnace should go onto cool down and shut off.
Depending on thermostat, you can tie thermostat wire together there. same thing should happen.
I agree that it could be thermostat.
