joerg68
Jul 22, 2020Nomad III
The Google brought up this old thread:
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26917562.cfm
Maybe it helps you to gain confidence. My own philosophy with these things usually is, if someone assembled it before, it can be assembled again.
As long as the problem is in the motor head, you should always be able to manually extend/retract. Just have the crank with you, or an electric drill with the right bit.
44,071 PostsLatest Activity: Aug 16, 2026
