joerg68's avatar
joerg68
Nomad III
Sep 10, 2018
Atwood Oven: sometimes no gas at pilot
Hi all, maybe you have an idea. We have had our new camper since June of 2017. Until a short while ago, the oven has worked just fine. Set to Pilot, press valve knob, light pilot light.
Now, about 50% of the time, we get no gas at the pilot. At all. Consequently, we can't light the oven. No freshly baked rolls for breakfast.
We checked all that can be checked without major disassembly, removed the burner shelf to access the pilot assembly, things look clean.
The three top burners work just fine, so do all orher gas appliances.
When we do get LPG at the pilot, it lights and the oven works as it should. But the pilot flame is not very big, about 1/2 inch.
I did check if the safety pin gets pushed in all the way when I push the knob; this seems to be the case.
Any idea/explanation? I am thinking that something in the main valve might be stuck, but a new valve is not exactly cheap and the oven is just in its second season.
eta: when it doesn't work, it will do so for days. At some point it just works again - until it doesn't. Temperature or elevation do not seem to make a difference.
