dave17352's avatar
dave17352
Explorer II
Apr 08, 2017
Atwood Water Heater shutting down fix
I posted a thread over on the Lance Truck camper forum about my Hot Water heater that would mysteriously shut down over and over again after about 5 seconds of ignition. I did some experimenting and this is what I found. I pretty sure this info may be helpful to someone else so I am posting it here also.
Update on my water heater.
Ok I have the absolute answer to what my problem was. Moisture on either the probe or control board or probe wire. I reproduced the problem probably 8 times without fail. It was working perfectly, then I went out and misted the probe and wire only. Went back in to fire it up and sure enough it shut down. Took my heat gun and dried it up and sure enough it worked perfect. Then I kept the probe dry and misted the control board and same thing. I ran the heat gun on the control board and if fired right back up. I repeated this 3 or 4 times on both the probe and control board and it produced the exact same results. So it looks like I will be keeping a hair dryer or heat gun on board. This actually makes sense because it acted up after filling the tank and when we drove through heavy rain going fishing. It was interesting to me that either one the control board or probe and wire would cause the problem. If it was just the probe and wire I would buy a new one. But sense it is both I don't think I will. So I guess that little mili amp feedback gets dissipated when wet.
So keep that stuff dry when you fill you Water heater!
My water heater is a Atwood 6 gallon G6A-8e Spec no 220038
Dave
