Traver8's avatar
Traver8
Atwood Water Heater T-Stat Question
Hello All,
Just needing a sanity check here. I recently had an issue with my Atwood water heater thermostat apparently not making good contact with the tank and creating an overheating situation.
I am going to replace the thermostat and am wondering if there is any reason NOT to add some heat transfer compound to that area to aid in thermal transfer. I don't think that it would hurt anything and cannot see any reason not to do it but thought I would ask and see if I am missing anything.
Your thoughts?
Terry
  • Traver8 wrote:
    Since some have responded with questions let me tell you the story and see what you think.
    I am living in my trailer for work. Normally running the water heater on electric. Left town and found some strange conditions when I returned.
    1. Water heater was left on and full.
    2. Water supply was turned off.
    3. My time away turned into two weeks.
    4. When I returned And turned the water supply back on, I found that the hot side seems to be really empty - took a long time to fill and get the air out.
    5. Water heater would no longer heat on electric, propane did seem to start and run.
    6. I found signs that the temp/pressure relief valve had released some water..
    7. When I removed the unit to check/change the electric element I found that the styrofoam cover was melted on the top of the tank.
    8. Confirmed that the electric element was bad and changed it.
    9. Now heated on both electric and propane but noticed the propane seemed to run poorly, restarting quickly etc.
    10. While checking the t-stat electrical connection I noticed that the propane would stumble a starting and stopping quickly.
    11. Used my IR thermometer to try to check water temp. found it to be hotter than I would expect with the normal T-stat and believed that the ECO was stopping the heating.
    12. Finally managed to reseat the t-stats and get things running correctly again but want to try to reduce the chance that this will happen again.
    Anyone want to render an opinion on my conclusions?
    Thanks,
    Terry
    Sure thing...
    Do NOT leave water heater ON (electric or propane) when away and with water supply valved out.
    Doing so created your issues.
    Water temp slowly dropped so t-stat called for heat...element heated water and then t-stat secured heating.
    But over time (2 week period no water supply) water in WH tank absorbed the air pocket and then dissipated via weeping T&P Relief valve until lack of water level caused tank to start getting hot from heating cycles.
    Normal t-stat continued to function controlling heating cycles otherwise the ECO would have shutdown heating and 'locked out' any further heating (Red Fault Light ON----has to be reset by turning ON/OFF switch OFF then back on before more heating could occur)
    Don't see where you had the Fault light and had to reset it.
    SO.....
    DON'T Leave WH ON w/o water supply ON and unattended for days/weeks.
  • Since some have responded with questions let me tell you the story and see what you think.
    Thanks,
    Terry
  • For the thermostat not to make proper contact with the tank there had to be improper installation when heater was assembled or the spring that keeps tension on the therm. broke or one of the three "ears" that retains the collar and spring arrangement has broken in which case just installing a new therm. is not going to work
  • Old-Biscuit wrote:
    Not needed...
    Just clean tank wall and make sure t-stat is held tight against wall.
    My daughter brand new TT had a problem with the water heater not re-lighting. After 2 (or was it 3 ?) attempts by the dealer (including a charge for re-adjusting the flame sensor), simply cleaning the t-stats and the spot where they contacted the tank, solved the problem.
    OP - Curious, how did you realize the tank was over heating ? There is a PT valve just like on your home water heater tank, so you were not really in any danger. There is also a thermal fuse that will melt cutting off all power if thing got REALLY hot !
  • Not needed...
    Atwood hasn't seen the need in over 30 yrs.
