- RobertRyanExplorer
jimh425 wrote:
RobertRyan wrote:
I have seen the US Off Road TT's they are not built to take the pounding here.
There is no way to prove or disprove that statement, but I'm pretty sure you haven't seen "every" US off road TT. But, what difference does it make in the TC forum?
I have " seen" all the Off Road capable US TT' s online and none have a dedicated chassis. Suspension systems are basic. Makes sense as they are not required to Off Road for many months at a time. If you did build the way tbey do here, they would be very expensive. Not worth it for the use they would get - jimh406Explorer III
There is no way to prove or disprove that statement, but I'm pretty sure you haven't seen "every" US off road TT. But, what difference does it make in the TC forum? - RobertRyanExplorer
jimh425 wrote:
RobertRyan wrote:
Not that simple. They do not flip springs
Of course it isn't "just" about flipping springs. :D So, you are saying the springs are under the axles in Oz? I didn't think so. :)
If you want to see what's available over here, do some off road trailer searches. It's a niche market here as well but there are models for many different purposes including extreme here as well.
I can tell you that the Jayco Baja model is remarkably higher and shorter than a normal TT. It's nothing compared to the models made to pull behind Jeeps offroad over here.
I have seen the US Off Road TT's they are not built to take the pounding here. Off Road TT market is fairly substantial. A Off Road Caravan has a substantial frame and specialized suspension. They are supposed to be Off Grid for many months without any damage to the unit. - jimh406Explorer III
I can tell you that the Jayco Baja model is remarkably higher and shorter than a normal TT. It's nothing compared to the models made to pull behind Jeeps offroad over here. - RobertRyanExplorer
jimh425 wrote:
RobertRyan wrote:
More like this the Caravan acts like a very large TC, then you have smaller boats and extra on the tray. Quite common for Pickups, not just a F350 in this case, but SUV's as well but minus the TC space on the back. It comes down to you want a smaller living area but want to tow a boat or a much larger living area but cannot tow a boat?
Totally familiar and see similar setups here. They just flip the springs to be on top of the axle and gain a lot of clearance. Some models like my wife's uncle's Jayco start that way.
That's not any different than that type of TT over here. We just have the extra option of giant TCs.
Not that simple. They do not flip springs, specialised suspensions to make the Caravan and Pickup survive otherwise ride would be awful..Several on the market and used by manufacturers. Giant TC's are still smaller than TT's . That is the trade off. Not 20ft long.
That is what you weigh up making the decision what to use - jimh406Explorer III
That's not any different than that type of TT over here. We just have the extra option of giant TCs. - RobertRyanExplorer
jimh425 wrote:
RobertRyan wrote:
Off Road Caravans are the Trailer. You can still put a Slideon on the bed as well, most put boats on the Pickup
I've got that. How do you tow a large boat with the trailer connected? How about a toy hauler? NOTE: I know you can't. That's my point.
Not saying one is better. They are different.
Obviously, you can double tow technically, but have you tried maneuvering with a 75 ft combination? A bit of an issue compared to a 50 ft one.
More like this the Caravan acts like a very large TC, then you have smaller boats and extra on the tray. Quite common for Pickups, not just a F350 in this case, but SUV's as well but minus the TC space on the back. It comes down do you want a smaller living area but want to tow a boat or a much larger living area but cannot tow a boat? Taking into consideration that the living area in this case would be on the back of the F350 for a TC rather than the Caravan.
Obviously, you can double tow technically, but have you tried maneuvering with a 75 ft combination? A bit of an issue compared to a 50 ft one. - SidecarFlipExplorer III
jimh425 wrote:
RobertRyan wrote:
We use Off Road Caravans to replace larger Truck Campers. They can go off road as much and they have lot more amentities Smaller TC's and Hybrid Caravans are they way to go for really tough Off Road environments
Different, not better or a replacement. Can't tow a large trailer with a trailer on the hitch already. That's why most kinds exist in the US. ;)
In some states you can. Galled 'recreational doubles'. Michigan is one. Having said that, I don't want to. Bad enough toting my quads on the trailer hitch. - RobertRyanExplorer
https://image.ibb.co/hvffXQ/image.jpg
