NJEagle314
Apr 07, 2016Explorer
Straight from the Owner's Manual. I have the 3.73 rear
K-2500 (4WD)
Engine
Axle
Ratio
*Max.
Trailer Wt. **GCWR
8100 V8 3.73 10, 100 lbs.
(4 581 kg)
17, 000 lbs.
(7 711 kg)
4.10 12, 000 lbs.
(5 443 kg)
19, 000 lbs.
(8 618 kg)
* Weight-distributing hitch tongue weight 10% to 15%
of hitch weight 1,200 lb. (544 kg) maximum.
**The Gross Combination Weight Rating (GCWR) in
the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo,
equipment and conversions. The GCWR for your
vehicle should not be exceeded.
You can ask your dealer for our trailering information or
advice, or you can write us at the address listed in your
Warranty and Owner Assistance Information Booklet.
In Canada, write to:
General Motors of Canada Limited
Customer Communication Centre, 163-005
1908 Colonel Sam Drive
Oshawa, Ontario L1H 8P7
K-2500 (4WD)
Engine
Axle
Ratio
*Max.
Trailer Wt. **GCWR
(4 581 kg)
17, 000 lbs.
(7 711 kg)
4.10 12, 000 lbs.
(5 443 kg)
19, 000 lbs.
(8 618 kg)
