CampingN_C_
Apr 07, 2016Explorer
Well I guess I'll be the one to be go against the grain. Tongue weight on that will be every bit of 1500LBS. Not that the truck won't handle it in general but, that combined with a shorter wheel base personally, I think you'll find the towing experience less than desirable. Overall length of your camper is close to 38 ft !
I have virtually the same camper and my last TV was a 2005 2500HD. I put thousands of miles on that combo and never got it dialed in right.
My 32BHDS was sitting at 1380LBS on the tongue with two empty LP tanks. Jayco's published weights are VERY conservative, as I've said on here many times.
Reese DC with 1500LB springs bars no less is the hitch I'd go with if you decide to pull the trigger.
