drsteve
Apr 09, 2016Explorer
You'll be close on your weights, if not a little over on some, but you should probably be OK... unless there's a strong crosswind, or large trucks passing you on the freeway, or heavy rain, or you're going downhill, or uphill, or around a curve, or you have to brake hard and/or unexpectedly, or make a sudden course correction, or some unpleasant combination of the above. Those are the moments when you find out just how good your setup is. I try not to be the weight police, but that is a lot of trailer for that truck.
44,070 PostsLatest Activity: Sep 18, 2026
