smkettner wrote:
Just saying if someone is dragging out a macerator, connecting or just wrestling with the hose, pulling caps & valves, disconnecting, rinsing and putting away.... what is the big difference to using the standard sewer hose?
OK you can pump uphill or at home etc, otherwise it would seem to be even more hassle with a macerator.
I could see if all was permanent mounted in the big A utility compartment but we are talking trailers.
the big difference is that instead of a corrugated 4 inch pipe that has water/stuff hanging up in all of the grooves and is a mess to store, you have basically a garden hose that cleans and empties completely.
until you have tried both, you don't realize how "nice" a macerator or sewer solution is.
bumpy
