camperdave wrote:
As to the water usage, yes the Sewer Solution does use water. But probably not as much as you may think. It's shooting a very fine high pressure jet of water through a very small hole, and it only takes a few minutes to dump. I've never actually measured how much water it uses, maybe I'll figure out some way to do that. Any good idea's of how I could measure the amount of water used to dump vs. the gallons of waste dumped?
Anyway, I bet the amount of water used by the Sewer Solution is less than the amount of water I use in backflushing and cleaning the tanks through the built in sprayer thingy. :)
4) Can I use the SewerSolution to transfer waste to a mobile tank??
The SewerSolution adds extra water to the discharge because it is a water powered jet pump. The total load in the mobile tank will be about 140 to 150% of the waste pumped. In other words, if you remove 10 gallons of waste from the RV sewage tank you will have a total load of 14 to 15 gallons in the mobile tank. The actual amount of fluid added depends on length of hose and any uphill pumping. More hose and/or pumping uphill add more water to the load. Also see #11.
http://www.sewersolution.com/faq.htm
