JJBIRISH wrote:
Dumping to a cleanout at home is most likely a violation of law in most municipalities anyhow, they would generally have stiff fines for doing it if you were caught dumping there…
Again the sewer solutions use almost twice the water to dump the tank (double the effluent) and then use more to flush the tank, the amount of water used to pump it up grades requires higher volumes as well as well…
They work but should be banned from use…
It's my stuff. Shower water and other. If it didn't go into the trailer, then down the pipes at home, it would have gone straight into the house. And used a whole lot more water than even the Sewer Solution added, what with the 1.6 gallons/flush residential toilets and high flow showers with big hot water tanks (relative to the trailer). I don't see what the big deal is.
clogging is a real issue with the SS (can't speak to a macerator). Heaven forbid someone drops a wet wipe into the black tank, that's a messy manual cleanout job. yuck.
