JJBIRISH wrote:
Again the sewer solutions use almost twice the water to dump the tank (double the effluent)  and then use more to flush the tank, the amount of water used to pump it up grades requires higher volumes as well as well…
They work but should be banned from use…
well I don't think it is quite twice the water considering that some folks who use a stinky slinky have one of those back flow devices and fill up their black tank 2-3 times to get the crud out, and that Stinky slinky rinser attachment I just saw at walmart probably uses quite a bit of water to get that slinky clean.  I assume then that you also think that those back flow devices should be banned?
bumpy
