DE88ROX wrote:
I'm a little reluctant to use the Mr Clean Eraser, because its basically a form of very fine sandpaper. I don't like using it on walls, counters etc. Because its basically sanding the stains off. I noticed this one day after the wife used it on some interior walls of our house.. the sun was hitting that area just right and you could see every area where she had used the magic eraser.
Yep and I just don't think it's smart to use something abrasive on an awning since they are probably all coated with an extremely thin UV protection finish layer that you don't want to "scrub" off.
I use 303 both as a cleaner and protectant on my vinyl awning. For real heavy spots I will use Simple Green sparingly.
Larry
