Hello, I am enquiring about a 2005 Chevy suburban 2500 that is for sale in Dallas Texas. They are asking $9,995. It's done 120,000 miles and was a one owner vehicle with a very good Carfax history. (I...
I think you meant to say the axle ratio of the vehicle. Look in the glove box of the Suburban for a factory options sheet that will have a code to indicate the gear ratio when the suburban was built.
There is no axle ratio for the trailer, only an axle weight limit per axle like 3500 lb etc. Two axles would mean a total 7000lb capacity.
The gear ratio of the vehicle will determine the max load you can tow.
