Just setup the equalizer hitch on my 2015 coachmen and now I am getting a creak from the trailer axles. Should I need to lube something under there or does it need a break in period. I know it's not t...
Does it creak if you jack it up with the ball disconnected so you're only lifting the trailer?
It might be the bushings as they are just a plastic sleeve on most trailers. Can you isolate the noise side to side buy having someone else jack the tongue while you crawl underneath and listen? Just leave it connected to the ball so if the jack decides to fail while you're underneath it wont crush you.
