vlopddap
May 23, 2014Explorer
wmoses wrote:
If the only issue is the clearance in way of these triangular brackets when going up your driveway and if you are level at all other times AND if you don't otherwise need the height increase, I would simply remove the brackets.
Thanks for the advice, but keep in mind it's a VERY small TT, so the sewer drain outlet is located very near of those triangular brackets, so if brackets rub, the sewer drain will rub and this can turn into a nightmare. The triangular brackets are the same height than the sewer drain actually.
44,056 PostsLatest Activity: May 04, 2014
