wmoses
May 23, 2014Explorer
vlopddap wrote:
Thanks for the advice, but keep in mind it's a VERY small TT, so the sewer drain outlet is located very near of those triangular brackets, so if brackets rub, the sewer drain will rub and this can turn into a nightmare. The triangular brackets are the same height than the sewer drain actually.
Okay then the brackets can't be removed. On my equally small hybrid (17') with the same brackets, the sewer pipes were just aft of the wheel so removing the brackets would not have caused any problems. Sounds like you will have to flip the axle afer all. Others have done it successfully.
44,056 PostsLatest Activity: May 04, 2014
