69_Avion
May 29, 2014Explorer
As the height of the trailer goes up, so does the vertical center of gravity. Will it perform as well in a fast, tight turns? No, but if you aren't taking tight turns at high speeds you should be fine. Keep the heavy items that you pack in your trailer, on the floor and forward so that you have plenty of tongue weight and you should be fine.
Improper loading with insufficient tongue weight will create much more of an issue than your increased height.
44,056 PostsLatest Activity: May 04, 2014
