JIMNLIN wrote:
673.....
Yes worn bushings can cause all types of tire wear....then add a axle with the wrong camber and some odd patterns really show up.
Your best option for axle R&R on your trailer is a big rig trailer repair shop. They can replace any suspension part....add a spring in the pack....make suggestions....and bend the axle stub or the axle stub back to specs or replace the whole axle assy.
You really need to get your trailer axle weights before spending money on a over loaded axle.
Ya, this is the direction for sure. Per my earlier post, I was struggling to find a shop, but I kept digging around and finally found a shop that specializes in frame and axle alignment and many other items. It's an hour from home and the process is expensive, especially if axle bending is required, so getting all of the accurate data prior is the only way to fly.
Thanks again all
