Turtle n Peeps wrote:
frankwp wrote:
I'll have to try driving a new diesel. When I got my 8.1 in 2003, I drove a duramax to compare and was most underwhelmed. So not worth the $$$. But that was then & this is now & things have changed big time.
You should because things have changed a lot just like you said. Back when you bought your big block it had 340 HP and the diesel had only 300 HP. 40 HP is a big difference and couple that with the instant HP feel that the gas engine gives is going to be a lot.
Nothing wrong with kicking tires.
I'm curious how heavy of a trailer you towed with your 8.1 and what kind of mileage you got while towing?
I also have an 03 8.1. It is in a Silverado. My toy hauler is a little under 10,000 lbs empty and has a gross rating of 12,900 lbs. and I am close to the max if I fill the water tanks and have all of the atv's.
I get about 6mpg towing this trailer. It is very tall for a bumper hitch rig at about 13' high per the brochure.
