- richny02ExplorerThanks all! Yep, it was a 2" ball.
- OasisbobExplorerMy Bantam B-19 is a two inch. That is standard on smaller trailers.
- ppineExplorer III2 5/16 inch hitches are common even on light hybrid trailers.
I had a 2750 pound rig with that size.
Most trailer companies buy frames that are already made up. - wanderingaimlesExplorerMost hitches have the Ball size requirement stamped right into the hitch assembly. It may have been painted over, but it should be there.
As a generality, Trailers over 5000 pounds will go up to the 2 5/16 Ball size, less than 5000 lb may stay with the 2". - LynnmorExplorer IIMost trailers are 2-5/16", you need to check.
- nypatnvaExplorerI'm pretty sure it's 2". most trailer are that size
44,068 PostsLatest Activity: Jun 21, 2026
