SoCalDesertRid1
Dec 13, 2013Explorer II
garryk6 wrote:I'm seeing rivets at each framing joint in the walls. The bottom appears to be i-beam shapes that fit into one another. I don't see any rivets in the bottom, but I don't really see any welds either.NightSailor wrote:Sailor,69 Avion wrote:I don't get this? The Barth is all riveted, and all aluminum framing. The Barth has no welding anywhere.
That is similar to the Avion, but I like the Avion's riveted construction better. I like the Barth's bottom section better for structural integrity.
It has a larger volume and more interior space. The edge the Avion has is its lighter weight, and better aero-dymanics. It would be easy enough use the same techniques used to build the Barth to fabricate an aluminum bottom section on an Avion--which would make it indestructible.
I agree that Avion should have gone the direction of your Barth. Ozone question about your framework. Is the framework riveted, screwed or welded? I can tell the skin is riveted like the Avions, but couldn't tell from the pics about the framework.
Thanks!
Garry
