RRM63 wrote:
I have a 2012 Grey Wolf by Forester. Was having some problems with electrical as battery was going bad. Put a new battery on and now everything works fine as long as power is plugged in, but if power is not plugged in, most things don't work. These things that only work if battery is hooked up, work fine as long as power is plugged in. (lights, water pump, water heater, fridge controls, slide out, awning, etc.) All fuses and breakers seem to be fine and battery is strong.
Any ideas?
Rick
Not sure how soon the batteries are dead but there is a lot of parasitique drain on the batteries so I use a disconnect at the battery terminal. FWIW
