Tiggs's avatar
Tiggs
Battery Case Tie Down Straps
Just got my new battery boxes for the 6V batteries I bought. Imagine my surprise when I simply lifted the 12V, box and all off the angle iron frame. Isn't it supposed to be ....um... attached to prevent your battery from hopping off the tongue frame when you are motoring down the road???
So, I'm looking at my new boxes and the straps that came with them. I figure I can just strap the battery box to the angle iron using the straps but I don't like the chinsey buckle arrangement that I found to be a pain in the butt with the 12V. Wondering if I can just use a continuous loop cam strap around the frame and the batteries to cinch down the entire case to the frame without drilling holes in the frame to permanently mount the battery boxes? Or is there an even better way?
Thanks,
  • I thought the strap was supposed to hold the lid on ;-)
  • As a classy upgrade there are aluminum boxes designed specifically for batteries that bolt to the A frame and are lockable.
  • On some trailers I have run self tapping screws through the bottom and into the steel. On other trailers I've done nothing. I haven't lost a battery either way.
    The strap is meant to hold the battery and box in place.
