facory wrote:
Battery voltage without park power is 13.0 - 13.3 volts.  Voltage when plugged into park power 14.4 volts.  So I know it's being sent from the converter to the battery.  However, incoming voltage at the converter measure 2.3 volts.
You are confusing the issue.
The "incoming" voltage on the converter is 120 volts AC.
When unplugged from shore power, it is ZERO and whatever you measure there is meaningless.
If the batteries measure 13 volts with no shore power applied, they probably are good and the power is being lost somewhere down the line.
Start by measuring on the battery cable CONNECTORS (not the actual battery posts).  If it's still good, next check the voltage on both sides of the disconnect switch.  (Are you sure the switch is in the right position?)
Next would probably be checking that the negative battery cable actually has a good ground connection.
Next look for DC fuses that might be blown.
