danimal53's avatar
danimal53
battery questions
i have a few battery questions. First, can anyone tell me what kind of battery this is? How many amp hours etc? I'm not sure how to read the label.
i'm assuming it isn't the best battery there is, as it came with the TT from the dealer. What would a recommended upgrade be? not the best of the best, but maybe mid level
i'm also considering adding a second battery. is it okay to mix-n-match or should they be the same?
I'm pretty sure this is not "maintenance free" so where does one add water?
When disconnecting the battery, what is the proper way to do that? I mean, I know I have to unscrew the nuts and get the wires off the studs, but is there a certain sequence? or risk of getting shocked or something?
There's a little bit of water sitting in the bottom of the plastic box, is that a problem? I'm assuming it should be drained.
12v stuff is pretty new to me, been all over the internet gathering info. I figured if a post pictures of what I actually have someone can give me specifics, thanks!
