opnspaces
Jan 14, 2020Navigator III
If you're not running the furnace then something is definitely dragging your battery down prematurely. Check if there is an antenna booster button behind the TV. make sure it is turned off when not in use.
See if you can also get a make and model off the refrigerator, there might be a label inside the door. Some refrigerators have a heated strip on the door that pulls a lot of power.
Maybe visit the trailer while it's dark outside and open all the compartments both outside and in. See if there is a light that got left on that is drawing power.
If you have an inverter make sure it is turned off when not in use.
