Flapper
Feb 11, 2020Explorer
For basic use, the charger you have will be fine. Yes, there are better built ones on the market, but just increasing either the size of the battery or going to 2 6v may only mean that your current charger will take longer to charge. Yes, it will fully charge the batteries - but may take a few hours more. I've used the stock WFCO chargers for several years now with 6v batteries.
My old Jayco did have a "glitch" with 2 6v, however. They saved money by using smallish wire from the converter to the battery. And protected it with an in-line fuse. If the batteries were deeply discharged, the converter tried to supply more current than the fuse could handle, and it would blow. Per the master tech at the dealer, the cheap solution was to buy a resetting circuit breaker. It just plugs into where the fuse goes. If it blows, it automatically turns itself back on and charging continues.
My current Grand Design has "beefier" wiring and fuse, so that has not been an issue.
