Devo the dog wrote:
Grit dog wrote:
OP, as you see by the responses...
You’ve asked a crystal ball question that is frankly pretty silly.
Given you have a high $ truck that is a garage queen, I’ll presume you’re an older person.
In other words, Grit Dog thinks you're old, he has an issue with you owning an expensive truck that's a garage queen, and he thinks your question was stupid to ask. His words were "frankly pretty silly."
Typical of Grit dog. It appears that he doesn't like older people, especially when they ask questions that he doesn't like. And it's obvious from this and many other posts that he doesn't like people who can afford expensive trucks. Furthermore, it really rubs him the wrong way if you can garage the truck.
I've only had batteries go bad at the worst time, primarily because there's never a good time. They aren't expensive and not difficult to replace, if you want to do it yourself. Also, if you have AAA, their prices to replace batteries are very reasonable. So if you have AAA, it's not much of a gamble unless you end up in a situation that's time sensitive. Also, if you have a shop that you take it to for regular maintenance, the next time it's there, ask them to check the battery.
Buddy, your infatuation with me and 12V is a little creepy......
Correction, alot creepy.
PS, you profess to know alot about me. Are you psychic or the other word that is very similar in pronunciation?
