Rolling Condo wrote:
Most who camp without power use a pair of 6V golf cart batteries in series. Also upgrading to LED lights. If you need to recharge using your vehicle, use heavy duty jumper cables and not use the umbillacal cord. The wiring is too small to recharge the battery efficiently.
I wouldn't say "most" use a pair of 6V batteries, but it is certainly a good option. We use 2 each GRP 24 Deep Cycle 12V batteries. I personally believe that the dual purpose batteries are OK too for most applications, but they're usually the same price as the deep cycles, so there's no real reason to use them. However, I have seen dual purpose and deep cycle batteries side-by-side on the shelf, and the dual purpose had way more amp hours than the deep cycle.
We use Wal-Mart brand batteries in our TT and our boat. They hold up just fine for several years if you maintain them properly and protect them from the elements. I keep the battery receipts with the batteries, because you can always find a wal-mart in the event the battery fails prematurely. But to each his own...I've seen Wal-Mart batteries fail quickly, and I've seen them last longer than the fancy Optimas. I've seen Interstate batteries fail in a month or 2, and know of some NAPA batteries that melted under the hood of a truck.
