Atlee
Aug 02, 2016Explorer II
Are you talking about the selectors on the AC unit? If you are, that is your problem. Nothing connected to the AC will work off of 12v electric. The AC fan only will only work if plugged into 120v AC circuit or have a generator running.
firefightersink wrote:
Thanks for the info. I will check the fuses again. Thank you for the diagram, mine didn't come with a layout so this will help. And my selector has fan/AC/heat. Fan has a selector for lo/hi/auto and that is what i was looking to run on 12V. I have 2-6V batteries which were just replaced and I have about 256 amperes from them and they were fully charged. The fan ran before and this was the first time I had an issue with it only running of the generator power. Again, thanks for the info.
