westend
Nov 16, 2017Explorer
You should check all the wires for continuity to frame ground. That will definitively expose the (-) phase wire to be connected. There is no answer to what the green wire is for as one would need to trace it to find what, if anything, it powers.
With the battery correctly connected your lights, fans, water pump, electric ignition water heater, and electric ignition furnace should all operate. You should also have a path of current to the onboard converter for charging. There should be a circuit breaker or fuse for the battery main cable within a few feet of the battery.
