Flashman wrote:
Housted wrote:
I installed it on my 2015 RAM 3500. Real happy with it, I have to manuver slowly in reverse to park my 5er. Very easy install, a bit pricey, but it works great. BTW I have the Aisin trans.
Housted
Where did you mount the switch - brand new truck and am reluctant to drill into the dash.
This is one of those must haves, it simply prevents 4 wheel drive steering bind. This makes campground maneuvering so much easier. In 2 wheel low, the Cummins at idle generates more than enough power to move the truck and RV during maneuvering, even on soft ground. This allows you to keep your foot on the brake pedal and removes any chance of throttle lurching.
The kit has nothing to do with the transmission, it uses two relays to modify the signals going from the four wheel drive module to the transfer case.
This is the kit I bought for my 2015 3500;
https://www.amazon.com/BD-Diesel-1030705-Unlock-Kit/dp/B01HZV41G0
I mounted the switch on the panel below the headlamp switch. There is nothing behind this panel and a good place to mount switches.
