petoworx's avatar
petoworx
bed liners
hello all,my chevy came with a drop in bed liner,had tork lifts installed and reading through the brochure it states do not use w/bedliner. i have rubber 3/4 inch mats between camper(no sliding) should i take bed liner out?? confused, thanks pete
  • You read the origial warning, you read several of us warning...
    Yes, it is your TC... and it'll be yours to repair if you end up with bottom rot on your camper...
    Someone will remember and bring it up again.
    Good luck to you.
    sleepy
  • I am surprised that anyone is loading there camper on top of a plastic drop-in liner. Rubber mat or not.
    That was about the first thing I learned not to do when I got involved with truck campers.
    Paul
  • I also had my truck bed sprayed with Line X and love it. I would never have a drop in bedliner as they are too slick and causes more damage to the truck bed.
  • I'd remove the drop in liner and use a rubber mat only.
    No problem using a spray in bed liner and rubber mat too.
