ajriding wrote:
DO get a mat since u have bedliner, bedliner is slippery. The TC needs some friction between it and the bed, which the bedliner does not offer.
Options include old horse trailer rubber mats, heavy, thick but do the job.
I literally used a rubber floor mat/rug from HD.
Speciality made TC mat.
In a pinch a foam rubber pad would work too, though a bad long-range plan. When crawling on steep roofs I use a 3 inch thick foam pad, like what would come out of a sofa cushion, and the grip is incredible, should be same for TC.
OP’s bed liner is spray-in, putting a bed mat on top of a spray-in liner shouldn’t be a problem.
